Octy 3 Fault code - please help
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
   Component: BCM MQBAB H   H14 0106
   Serial number: 00011305000491
   Coding: 0F001B66424722FB07A04082B11C07280000000000000000000000000000
   Shop #: WSC 73430 790 00000
   ASAM Dataset: EV_BCMCONTI 010001
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 4689603AF9E6E52EEEF-8013
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119
   Component: WWS371 130131  041 0570
   Serial number:         130206203330
   Coding: 065DDD
   Subsystem 2 - Part No SW: 5Q0 955 547     HW: 5Q0 955 547
   Component: RLFS  024 0042
   Serial number: Y13M02D25H15M21S03S1
   Coding: 02805D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY130142YW9
   Subsystem 4 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000055968445
1 Fault Found:
2055 - Courtesy Illumination for Switch (Terminal 58xs)
          B133E 11 [009] - Short to Ground
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 229
                    Mileage: 16923 km
                    Date: 2013.10.23
                    Time: 19:02:32
Symptoms are
Headlight switch outer ring not backlit
LED downlighters not working
Switches in centre console not backlit (ESP, Stop/Start, Mode)
Wiper/Washer stalks not backlit
Does this point to a faulty headlight switch?
That or a cable fault.
Yep - dealer is now ordering a headlight switch but doesn't seem to keen on me pinching one off of their demonstrator for 5 minutes to check they have diagnosed the fault correctly (seeing as they missed this fault code entirely when servicing the car!)
Yep, wiring fault. Part of the loom behind the dash was pinched by the metal frame for the dash and had shorted this out.
Not good, how the hell this made out of the factory like this, wasn't picked up at PDI or service is beyond me.
Time to speak to SUK methinks.
