Part number for caliper sliders
Hello wondered if anyone would know the part number for standard fabia vrs caliper sliders i have been looking on line but they seem different to mine as one slider has a rubber inline sleeve fitted to it which is the one thats sticking the ones online don't have this are these updated pins?
Hi
Sadly you'll find that the slide pins for your vRS are only available as part of an 'assembly' 6Y0615125 (left) and 6Y0615126 (right) which includes the caliper carrier painted mint green the slide pins and slide pin bellows - expensive!!
If its the 'rubber inline sleeve' that's swollen causing the slide pin to stick - and you're able to get the old slide pin out - a reconditioning kit including the rubber sleeves is available from BiggRed.co.uk.
I had a similar problem and once I'd got the slide pins out and replaced the rubber sleeve the slidepins moved freely - just don't use copaslip but instead red rubber grease to lubricate.
Hope this helps
Mail me if you need any more info.
Alan
Hi again
Here you go. BiggRed Part number BRK205479 for the repair kit for both Lucas front calipers @ £27. 90. Think postage and packing may be included?
Other repair kits may be available from other suppliers!!
Alan
Edited by aak
