Identify my problem and advise me. Please.
Hello people, couple of problems with my VRS, hoping you wonderful people will know whats wrong and tell me what I need!
Firstly -
There is a slight clunk when the gear is selected for the first time. I.e When i put the clutch down and select a gear it donks. The clutch bites fine and has never slipped despite the 300lbft.
*I was told 'It sounds like the clutch isn't fully disengaging'
Secondly -
On cold start up the engine, or something in it, rattles. I changed the tensioner and the belt to no avail. if anything the colder she is the more it does it. After a short drive (2 minutes) the noise subsides.
my question is; Do you think the two issues are connected and would a new clutch and flywheel be advisable now?
If so, which clutch, best price etc. I can fit it myself.
Plans for the car this year are bigger turbo pd150, maybe an intercooler.  Power raised to a hopeful 200bhp with a bit over 300lbft.
Thanks in advance. Have a joyous evening.
does it make any difference on a cold start clutch up or down?
I will properly test this tomorrow morning but i can't recall it changing.
just as i recently had a rattle when the clutch was around biting point when cold and 1 -2 felt notchy .... turned out gear box was low on oil .....
maybe worth a quick check?
Ok! I shall check tomorrow hopefully. Thanks pal.
