Intermittent o/s front door fault
In the immortal words of Penelope pitstop "heeeeyyyyyyyeeeeeelllllllllp Heeeeeeeeyyyyyyyyyeeeeeellllllp ..... My drivers door unlocks and locks fine the led flashes as should but the courtesy light on the door and the interior light and lights on audible beepy thing works intermittently....... Any ideas anyone ???
Much love guys n gals
hmm sounds like a door lock mechanism gone awol or going awol.
Try to spray wd40 in the catch area of the lock whilst manipulating door by opening and closing it a few times.
A micro-switch makes a connection from the metal bar movement in the locking mechanism. This connection can sometimes get dirty and not make good contact, or the micro-switch can completely fail. so the door does not think it is closed so the door light and curtisy light stay on.
worst case is a full stripdown or replace the whole door locking mechanism. They have 4 micro-switches in them making them the most over complicated door lock ever....
If you feel confident you can strip lock down following this guide i did or just use it to help you remove the lock and replace it..
http://www.briskoda.net/forums/topic/126257-octavia-1-replacing-door-latch-microswitch/
Blinding cheers bowders !!:)
