Octavia I instrument cluster removal
Just found out that my car has couple of fault codes in but "check engine" light did not warn me(did not burn). Last owner must have pulled it out. How can i replace that?-How can i get instrument panel out? And DIY with pictures would be cool.    I have 2001 Octavia I
Post the fault codes logged in the ECU. N.B. There are several fault codes that do not cause the ECU to put the EML (check engine) on, so there may be nothing wrong with your dash cluster.
