Front Fog Lights doesn't work but cornering is ok
Yes thats it.
If i turn on the front fog lights in the switch they don't light up and theres no indication of them on the instruments panel, but cornering function works well.
Anybody knows what could be?
Do the rear fogs come on if you pull the switch out another notch?  Could be a faulty switch,
I assume you have the lights on whilst you are trying to turn them on?
Have they ever worked?
They may have been disabled (VCDS) either way a scan would be my first point of call.
yes i have the light on position on and not auto. The rear fog light works well
Does the fog light function share the same fuse as the cornering function?
i don't know... where can i see that info?
Faulty switch maybe?
Phil
In the manual...
As above, I'd try driving the car up to a glass / reflective window.
Turn the headlights on and then pull the switch out to the first position (for front fog lights).
Then wiggle the switch to see if you can get the front fog lights to illuminate...
Problem solved.
Activate cornering with Vcds (was activated in a Skoda dealer and since that the front fog lights don't work) and all works ok :)
Edited by Brandaopj
