FEW fabia vrs bits
Ok guys I'll try to keep all my stuff in here and update as I go along, I am building a 2004 vrs fabia rally car and there are a few bit's I won't be needing as I strip it down. car has done 85K and is 2004.
all prices are ONO and I would prefer collection from Ludlow sy84ad on these but postage can be arranged
1) passenger airbag unit, all good with brackets etc £20
2) black vrs headlining with matching interior light surround and handles/visors vgc £60
3) ac pump £30
4) Vrs/pd130 original intercooler, good condition no leaks £40
5) 6 speed gearbox from the vrs, available with sachs dmf and clutch and driveshafts (minus cv joints tho bare shafts) and hydraulic clutch pipe, ideal or a conversion £300 (only available as I am going 5 speed)
Edited by felicia16v
I'll take the horn if you could post please!
you don't want the suspension either.... ;-)
AC pump or AC condenser?
Assume if the whole system is coming up it either/both will be available?
ok I'll pm you my paypal in a bit when I get home
possible on that at the mo, it may already have a home
whole lot is out now mate what are you after. nothing is broken but there was very little gas in the system (100Grams)
condersor has a few bent fins from stone/water damage but nothing that should make it leak
gimmmmeeeeeee ill come collect too
Can you do me a deal for the alarm siren under the exhaust heat shielding, sort of under the nearside passenger seat base?  You can see the wiring going through a circular rubber seal in the chassis. :)
You might not even know its there.  See?  Weight saving advice right there!  ;)
you are welcome to the bloody noisey thing mate, next time I have it on the ramp I'll take it off.
it works ok anyway as it gets most upset about having no bonnet catch if I try and lock it up.
I'll get it off and see what the post will be..
Paid  :thumbup:
Paid  :thumbup:
Thanks , all boxed up and ready to go in post tomorrow morning mate
Got it off tonite mate if you are still after it..
hopefully everyone has got what I posted by now,
updated original advert  to delete what is sold and add a few bits
I need the passenger side air vent if your changing the dash.
