Enable single click unlocking?
Does anybody know the coding to enable single click unlocking of all 5 doors? There is a guy on ebay saying he can do this but he is not close and I know nothing about him.
Many thanks.
In the Yeti you can select this on the maxi dot in the menus.
 If not it is a simple adaptation in the VCDS drop down menus.
 Where a bouts are you in the UK?
Cent Elect - 09Coding - 07Long coding helperAutolock: Byte 0 - Bit 1Unlock: Byte 0 - Bit 2
That's the coding I used for mine
Sent from my GT-N7105 using Tapatalk
Alternatively
Cent Elect - 09Adaptation - 10Auto Lock/Unlock (set both to on)
As above you should be able to do yourself if you have maxidot
Only on the yeti, I've not seen that option on the Fabia mc, maybe I have missed that though?
Edited by jonro2009
Many thank to everybody - I'll try the maxi dot menus tomorrow, never thought to look there. I'm based on the Warwickshire / Oxfordshire border, near Hook Norton, a fine place!
