Fuel tank?
I have owned the yeti since August, just recently I've noticed the noise of the fuel sloshing about the tank more than normal. I always fill the tank up and let it run down before refuelling.
It's been years since I've heard the fuel sloshing around the tank in another car. The tank at the minute is just under 3/4 full.
Anyone else noticed this or is it just my super sensitive hearing?
No your not alone, have noticed it with both Yeti's I've owned but particularly this one. Worth bearing in mind it's only just behind you under the rear passenger seats, and unlike other Skoda's the Yeti doesn't have the seat base foam sat directly onto the floor pan which would normally provide some sound deadening properties.
TP
Phew thought I was being hyper sensitive.
Good point you make about the seat bases and foam not directly on top of the floor pan to insulate the noise.
Turn the music up  :rofl:
Nice idea. Doesn't work for reverse though!!
