VCDS codes
Any body know what the first code is because all the lights are working fine.
and the car is a skoda superb 09
 I know about the front fog lamps because there's leds in them
                Address 09: Cent. Elect.       Labels: 1K0-937-08x-09.clb
Control Module Part Number: 1K0 937 086 A    HW: 1K0 937 086 A
  Component and/or Version: BCM PQ35  M+  020 0358
           Software Coding: 48990AB89041F1C0401000841100012401F01BAE432081605C4040000000
            Work Shop Code: WSC 25086 576 94681
                      VCID: 2E53DF567937BC6E36F-807B
3 Faults Found:
01519 - Bulb for Back-Up Lights; Right (M17)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 171
                    Mileage: 209666 km
                    Time Indication: 0
                    Date: 2051.14.14
                    Time: 12:32:05
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.45 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01496 - Bulb for Fog-Lamps; Left (L22)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 171
                    Mileage: 209666 km
                    Time Indication: 0
                    Date: 2051.14.14
                    Time: 12:32:07
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.45 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01500 - Bulb for Fog-Lamps; Right (L23)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 171
                    Mileage: 209666 km
                    Time Indication: 0
                    Date: 2051.14.14
                    Time: 12:32:07
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.45 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Does it come back if cleared? It could just be the legacy of a blown bulb which has since been replaced. I have had similar from time to time but they usually don't come back after clearing.
yeah keep on coming back on, what are back up lights anyway
I'm not sure on that one sorry. But if you can locate them, it does suggest one has blown, given the fault stays, or else there is a wiring fault in the relevant circuit.
Adam
Are they Reversing Lights?
Surely back up lights is just an American way of saying reversing lights?
Try another bulb. (or swap the left and right one over and see if the error changes sides)
Ill try that tomorrow
thanks
