Error Code 44-Steering Assist -- Status: Malfunction 0010
Hi,
I have this error when scanned my car:
2 Faults Found:
16353 - Control Module - Internal Malfunction
            014 - Defective
             Freeze Frame:
                    Fault Status: 01101110
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 108
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    Battery Volts: 0.0 V
                        PD
                    Temperature: -70.0?C
                    Error Code: 0
                    Torque: 0.0 Nm
                    Torque: 0.000 Nm
                    RPM: 0 /min
16355 - Control Module - Watchdog Timer
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00101110
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    Voltage: 0.00 V
                        PD
                    Count: 0
                    Count: 0
                    Count: 0
                    Count: 0
I went to a vw dealer that says the error codes were not a failure and a software update could resolve this errors, but they were nothing.
Happen to anyone?
Errors like that can occur due to low voltage, the freeze frame data indicates 0 Volts, also a temperature of -70 deg C and a fault frequency of 1.  I would clear them and see if they reoccur.
i´ve tried to clear them, but they immediately appear again.
The car works perfectly without any issues.
whats the meaning of fault frequency? It only occurs one time?
And the 0 km?
Whats the meaning of reset counter value?
Edited by Brandaopj
  • 5 years later...
Hello,
How did you fixed these errors ?
