Bluetooth Issue
Trying to connect my iPhone 5s to my 2009 Octy vRS and it finds the phone but then tells me it is incompatible.
After some digging on here it looks like I must have the incompatible bluetooth unit. However I also have a bluetooth error on a VCDS scan. Can someone tell me if the scan results would be causing this problem or if it is in fact my bluetooth unit that is not compatible.
Also if someone could tell me the part number of the compatible bluetooth unit if thats whats required.
Address 77: Telephone Labels: 3C0-035-730.lbl
Part No SW: 5N0 035 730 C HW: 5N0 035 730 C
Component: J412 8506
Revision: 00019000 Serial number: 0000A07949606
Coding: 0020121
Shop #: WSC 46396 133 11833
VCID: 285BFC93E263
1 Fault Found:
00992 - Consumption Cut-Off Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 164
Mileage: 109229 km
Time Indication: 0
Date: 2115.14.06
Time: 15:30:46
Edited by Hungry Horace
buy a 3C8 035 730C or D
fault is probably due to lack of charge in the battery
