Fans came on tonight,should this happen?
Hello again.....
Right,got home tonight after a short journey of around 14 miles,andwhen I was going to reverse onto the drive I noticed the engine RPM was slightly higher than normal,around 900 RPM and there were fans running,which continued to run after I switched the engine off for a couple of minutes.
Is this normal?
There didn't seem to be any excessive heat and the coolant gauge was at the 12o`clock position.
The cars a 62 plate Vrs.
Thanks again peeps......
DPF doing a programmed regeneration, about every 400-600 miles, you get used to it!
Edited by Yorkshire
Cheers for the reply `Yorkshire`....looking on here I`ve actually found a few threads referring to it..these forums are ace!!
Thanks again....
Hi mine did it the other day, first time I noticed in 18,000 miles!
