TFSI clutch change, how to bleed slave cylinder
Planning to change my DMF on my TFSI. Seen a few decent guides on a clutch change but not much mentioned about bleeding the slave cylinder(fitting new one) can i bleed using the pedal? Is it best to clamp the pipe, remove box, fit new CSC and bleed? Does the new CSC have to be in its fully extended position or anything? Any help much appreciated
