Recommended tool/method for brake fluid change
Hi,
thinking of doing the next brake fluid change myself. What is the experience with using one of the vacuum sets which are available relatively cheap e.g. on ebay. Or should I rather look for pressure bleed equipment?
Thanks in advance.
I did my old Fabia with a Gunson easi bleed.
Easy to use and did the job perfectly.
As above,i used a Ezi Bleed when i changed mine,fluid was a bit slow coming out but did the job.
+1 for an easy bleed, they work well and top up as they go, simple to use and can be done on your own.
As above, go for the Gunson kit, dead easy to use single handed.
That's what one would call a clear vote, I guess  :rock:
I'll order one today, thanks a lot for taking the time to share your experience!
