Demon Shine Snow Foam
Has anyone tried this? With not having the joys of a pressure washer at present any thoughts on this would be appreciated.
The RS is caked after the governors missus had it for the last couple of weeks and time/weather permitting it will get a good going over on Sunday, so a decent pre wash is a must.
It's an 'acceptable' Snow Foam that will cling and clean when put through a proper lance, forget the built in venturi spray nozzle on the large bottle it barely produces suds, even with a proper lance it's nowhere near the likes of an Autobrite Magifoam or Bilt Hamber.  Problem I found with the built in applicator is without good foam the product can't cling and get to work properly, making it little more than a hose rinse.
As you are without a PW, if you and can get to an Asda/Halfords (think Asda have it cheaper) then I really rate the Demon Ranges "Rapid Dirt Shifter" as a pre wash mixed 1-1 with water in a £2.00 garden centre type pump sprayer.  If no sprayer used neat from the spray bottle it does a fine job too.  For me it works best applied to a dry car before the first rinse and given some dwell time.  Also very good for doing door shuts and detail work when agitated with a round brush.
Best of all Rapid Dirt Shifter is LSP safe in my experience
Top man. So, not worth a carrot then  :D
I suppose to save bu66ering around with spray bottles etc I might as well just go and by a PW or raid the old mans garage  :bandit:
Thanks again  :thumbup:
The Rapid Dirt Shifter comes with a trigger spray nozzle on the bottle and is happy to be used undiluted.
If you just treat the lower half you should whip around the car in a couple of minutes and it's a nice product to have in the kit bag as it will do engines, wheel arches, door shuts really well too.  Plus in my case is handy when I don't fancy digging out the PW.
£6.00 vs cost of PW + SF Lance, but that sir is your perogative.
Good luck, happy to help :)
Sounds like the way to go pre-xmas. I can just imagine the looks on the kids faces coming Christmas day, "there you go kids, a new pressure washer and snow foam lance, just what you wanted"  :rofl:
http://www.autobrite...-lance-kit.html
It's only one thread up from this so every chance you have seen it but this is probably the best lance and foam offer going at the moment
£45.00 Karcher K2 from the outlet and you're laughing.
http://www.karcheroutlet.co.uk/products/product.asp?id=5095
I use a K2 and AB lance and I've not seen any other more expensive set ups that do a better job.  Typically can get a good 20 mins cling from Magifoam with right conditions.
...and it's even cheaper at the moment at Asda...£4.80 instead of £6! Just ordered some...thanks for the info.
