Full scan on potential 4wd purchase - advice
I'm thinking of buying a Golf MkIV 4Motion to sit alongside my Octy VRS. Borrowed a VCDS cable from an Audi obsessed mate, and did a full scan on a car I saw this afternoon. Only a couple of fault codes, which isn't too bad to say its an 11 year old car. One looks like an ABS sensor which seems an easy and cheapish fix. The ABS light is on on the dash, so that would explain that one. I'm slightly cocerned about the fault code on the Haldex AWD system. Seems like this could be a potential disaster.
Any insight would be great. Full readout below. Thanks.
Sunday,15,December,2013,16:22:37:27904
VCDS Version: Release 11.11.6 (x64)
Data version: 20121223
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
          76
VIN: WVWZZZ1JZ3D015476   Mileage: 131940km/81983miles
Address 01: Engine        Labels: Redir Fail!
   Part No: 022 906 032 BG
   Component: MOTRONIC ME7.1.1    0004
   Coding: 0000132
   Shop #: WSC 01190 210 75197
   VCID: 51A39D04CB843A90FF5
No fault code found.
Readiness: 0110 1101
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-A.lbl
   Part No: 1C0 907 379 F
   Component: ESP ALLRAD MK60     0104
   Coding: 0023046
   Shop #: WSC 31414 000 00000
   VCID: 2D5BE1F4B77C3E70BBD
1 Fault Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
            012 - Electrical Fault in Circuit
Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 2.0.0
   Coding: 11000
   Shop #: WSC 31414
   VCID: 21430DC4ABA4EA100F5
3 Faults Found:
00532 - Supply Voltage B+
            07-10 - Signal too Low - Intermittent
01271 - Positioning Motor for Temperature Flap (V68)
            37-10 - Faulty - Intermittent
01274 - Air Flow Flap Positioning Motor (V71)
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 A
   Component: 27 AIRBAG VW51 01   0006
   Coding: 12855
   Shop #: WSC 31414
   VCID: 224102C8AEA2F10816F
Address 17: Instruments        Labels: 1J0-920-xx5-17.lbl
   Part No: 1J0 920 926 A
   Component: KOMBI+WEGFAHRS. RB8 V24
   Coding: 05414
   Shop #: WSC 00000
   VCID: 285510E0C89E1B5848B
   WVWZZZ1JZ3D015476     VWZ6Z0B0246199
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 31414
   VCID: F0E5B880B0CE939850B
Address 22: AWD        Labels: 02D-900-554.lbl
   Part No: 02D 900 554 C
   Component: HALDEX LSC  ECC     0010
   VCID: 204508C0A0AEE31800B
1 Fault Found:
01316 - ABS Control Module
            79-10 - Please Check Fault Codes - Intermittent
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799 B
   Component: 1X Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 31414
   VCID: 3669CE98122A7DA8CA7
   Subsystem 1 - Part No: 1C2959802A
   Component: 1X Tõrsteuer.FS KLO 0004
   Subsystem 2 - Part No: 1C2959801A
   Component: 1X Tõrsteuer.BF KLO 0004
   Subsystem 3 - Part No: 1C0959811A
   Component: 1X Tõrsteuer.HL KLO 0009
   Subsystem 4 - Part No: 1C0959812A
   Component: 1X Tõrsteuer.HR KLO 0009
Address 56: Radio        Labels: 1J0-035-18x-56.lbl
   Part No: 1J0 035 186 D
   Component:  RADIO SON         0004
   Coding: 00001
   Shop #: WSC 01059
   VCID: 26491ED8C28A0D287A7
1 Fault Found:
00856 - Radio Antenna
            36-00 - Open Circuit
Address 76: Park Assist        Labels: 1J0-919-283.lbl
   Part No: 1J0 919 283 A
   Component: Einparkhilfe        0001
   Coding: 00103
   Shop #: WSC 31414
   VCID: 2C5DECF0DC663778AC3
End   ---------------------------------------------------------------------
you will probably find the fault is related to the abs sensor issue as the awd system will need all four sensors to be working correctly.
That's what I though. Thanks Rover.
And it may not be the sensor, it could be damage to the wiring.
Sent from my phone so please excuse brevity and spelling
