Lambda sensor fault
Hello all!
What a great forum this is with much activity and knowledge :)
My Octy 2.0 AQY has had problems with the emissions and i have changed the following parts.
New lambda sensors (both of them), the Air flow meter, the engine temperatur sensor, and finally the Catalyst due to that was all gone inside.
I then got it through MOT inspection no problems.
But afterwards it has come up with these fault code occationally.
Faults
16518 - P0134 O2 Sensor Circ.,Bank1-Sensor1
No Activity Detected, 35-00
It can some times drive some 100miles with no motor lamp lit.
Can it be the Lambda sensor that is dead as i changed it some months before the Catalyst?
Thanks!
The wiring to the pre-cat sensor is faulty.
pin 1 -> +ve in loom
pin 2 -> ECU pin 27
pin 3 -> ECU pin 25
pin 4 -> ECU pin 26
The ECU pins are on 52-pin connector. There are no intermediate connectors - the wires go direct from the sensor connector to the ECU. Disconnect both ends and do continuity tests
Thanks, i`ll try that in the garage :-)
