Neuspeed Rear Arb Fitting
Does anybody have a guide or pics of how to fit 28mm Neuspeed rear on a mk1 Vrs?
:D use the force
Undo a bottom strut bolt
Tap out
Put new bolts threw
Pop link on
Do up
Repeat the other side
Offer bar up
Bolt thru middle hole and thru link
Repeat other side
Push bar to beam
Fiddle with brackets
If awkward like eibach i used a jack to hold the bar up while i did the brackets up
Check all tight
TEST DRIVE :)
Check in technical section if resident Thread Guru Bowders1 has done a 'How TO'
Can't find a How to guide unfortunately, Lloyd has given me some good pointers, so will give it a go.
I have an R32 front arb, but if I fit the rear without the r32 what will the effects be?
lol actually i have done one somewhere for the RARB.....
Fitting is simple on these
interesting that you can buy spares for the kit if needed.
Not cheap though.
http://www.neuspeed.com/2510287-neuspeed-rear-anti-sway-bar-28mm.html#popUp[products]/0/
Also Neuspeed has all sorts of installation guides
Here is the one for the RARB
http://www.neuspeed.com/media/attachments/21_25.10.25,28.8.pdf
comparison between old Whiteline and Neuspeed
fitted
Bowders thanks mate, that will all be useful, I am going to give fitting a go this weekend
I will report back how I get on
What size is the bolt going through the bottom strut and drop link?
M10x80mm buddie it seems :)
It shall be on for you friday matey :)
(uh oh they all say )
