De wiper bung size?
Does anyone know what size bung i need for dewipering the rear? I could remove and measure but dont fancy it in this weather.
Cheers.
Ill measure mine when i go out if no one has answered since.
Thanks mate that would be great.
You want how big the bung is or that actual hole size?
The hole size please, so i know what to put in it.
I think you can get glass bungs on eBay Joe, they are expensive but look really good.
Im cool with just black for now, cheers for the heads up though i will check them out.
Snap mine is the same one as Karl's, Joe order from that seller and mention Briskoda you may get a discount ;-) HTH.
Thanks guys. Isit a flush fit like that aswell?
Any pics of that fitted Karl?
Yes it is Joe.
I broke mine so just went and bought the only one that was in halfords lol. Lucky it fitted!
Lovely, will be ordering shortly.
As requested Matt
The kit I had also included some black mastic (Tiger Seal), one point to note when fitted it protruded about 2 mm further out then the rear screen so I just pushed it back a bit and held it in place with some masking tape until the mastic cured. Good job no leaks.
Karl   :thumbup:
About 30mm if you want the rubber grommit, hard to measure in the dark and rain :P
i fitted the one in the link above a couple of days ago, looks ace, cant fault it. Loads better than a rubber grommet imo!
