3sdm short life ?
Ok ... Today i went and had my alignment done on a funky laser thing
With all my camber settings and wound down coilovers :D
Well
Camber is -2.5 :)
Rear has toe in of 4-5mm lol
So seems like it will shred rubber in a not so fun way
Looking back i do love ch's still :)
As much as i love my staggered madness im thinking i may next want to try get the 5x100 ch blacks ;). 8.5x19s and loose a chunk of camber
Soooo if un damaged and like new tyres how much do we think the 3sdms would get ?
:D
Trouble is...... I do love it
4C98A52B-F8D2-4ED2-B75E-D22A9A82FB44_zps
Jeez Lloyd you must have a very supportive SWMBO mine would skin me if I changed wheels that often. Hats off to you though always evolving.
Ssssh she may hear us :D
Last will and testament of 1 LLOYD :D
Would 8.5 3sdms on the rear and less camber not be a more sensible option???
But I realise that you do work differently to the rest of us!!!
Im not a huge fan of the 8.5 :p
I only bought them for the rears :D
I may just use cheaper tyres lol and sacrifice them in the name of cool lol
Theres some achilleseseseeses things that are cheap ? I could feed them to the camber lol
They always do they are omnipresent. (Everywhere) in case anyone's struggling.
Toe in of 4/5mm??
Are you using camber plates on thr rear hub?
That needs sorted asap as thats dangerous
Yeah shims behind the hub... The eibach things
They wernt to concerned due to both rears being like it, was told the tyres will just end up mushed even quicker
You not thought about running eibach ez shims as they can be used to adjust camber and toe?
Thats what these were meant to be ... Eibach ( from venom )
Maybe if i get the 0.5 turn sideways tonact likeva toe shim then ?
Mine on the vr where adjustable alloy custom made jobbies. Did camber/toe and stopped the wheel sitting forward when lowered. They also gave me 5-6mm :)
F3A5AC27-E31B-4707-9268-A89B53B06C20-517
11215A06-3C19-4294-A6F5-9972D9C08124-755
Do they do them for mk1s mate ?
Who did them
Thinking to rip the rims n camber off in few months
Or if someone wants to give me 6 grand or such they can do it :D
What do u think the 0.01s would fetch ?
New rims
New rubber
lloyd for the amount of miles you do it will probably take you 5 years to burn through a set of rear tyres even with them settings :)
I said the same thing in one of his other threads,just think he's having one of his wobbles,car will be up for sale tomorrow lol
Lloyd,don't get yourself down as the car is fine and looking well so keep your chin up :)
Was almost up for sell tonite
It was case it was said abit further up its dangerous ;(
If just gna munch tyres then no probs there :D
Its only falkens and if kills them with a thought then it could be kangs or achililililes i'll feed the octy as they r cheap as chips
Its 3.7 one side
5.00 the other
So dif is 1.3mm
They said its pretty evenly fudged so its just tyre wear id get
After looking thru all my pics....
I think i may get away with popping 1 of the shims out ( maybe both if i get fed up and cant afford the time i take up )
If i wait with the car while they do it and see what happens if they take 1 out or both
Hmmmmm
Aaaaaaaaargh
