VCDS Tweaks for VRS
I have access to my neighbours VCDS and wonder what tweaks are available for my VRS?
The factory options on the VRS are f&r parking sensors, adaptive xenons, heated seats, maxiidot
Retrofitted: mfsw, columbus, bluetooth.
Is there anything on the elegance spec which is not enabled on the VRS?
On the maxidot i can change settings for the drls. coming and leaving lights,  but not the parking sensors.
Also, in the "assistants" menu there is heading "Bend" which is ticked. Am I correct in assunming this is for the AF xenons?
Have you got the rain/light sensor?
And yes the "bend" the for the AFS xenons.
Phil
Phil
Yes Phil, I do have auto lights mirror and rain sensor
Then you could also enable rain closing which will close your windows should you leave them open and it starts to rain.
Oh and for the parking sensor options there's a separate controller for it in VCDS and you can change the frequency and volume of the beeps.
Phil
Thanks Phil
I will have a go. Is is easy to find and change for a complete novice?
