Can I disconnect battery ?
Hi just wondering if I can disconnect my battery without having to reset anythin with vcds ? Cause I need to swap my melted fuse box and alternater cable I don't have vcds so don't wanna be left stuck thanks
I replaced the battery a while back no ill effects and no need to use vcds.
There should be no problem, but it would be prudent to make sure you have the radio code - just in case.
I disconnect mine all the time no problems at all although your car might feel a bit different while it re learns things as the ecu will get reset
Kk cheers for quick reply I have a aftermarket sterio anyway so that won't be a problem thanks
