MAF replacement guide
Are these easy to remove and replace in Fabia VRS 62 plate. My last car was a mk4 golf V6 and the job was a 10 minute one.
Do they need replacing every X thousand miles ? I like to keep my car running well and not wait till parts fail. The car's now done 11000 miles.
Thanks in advance.
Stu
Are you going to be having your car Serviced with a Skoda Dealership on Fixed Servicing?
annually/9,400 miles or Variable/Flexible Servicing Oil & Filter when the Maxidot shows.
Are you asking about the 'Air Filter' being replaced,   or a 'Mass Air Flow Sensor' ?
The Air Filter is easy to check to see if it requires replacing,
Look at the Air Box, see  the tool that is required to open the lid, if you have not already done that,
If you do not have the correct Torx head you will need to get one.
but unlikely it does need replacing at 11,000 miles if it never got wet, full of dust/dirt from driving in quarries/deserts or sitting behind city busses.
The Pollen Filter for the Cars Interior is due to be replaced at the 24 month Inspection Service/Major Service..'
http://www.skoda.co.uk/owners/service-and-maintenance/national-pricing/servicing
george
Thanks for reply. I have already changed the air filter. I was talking about the flow metre. Where is it on the tsi ?
