fault code 17569
any ideas guys doing my head in
where is the
  • Manifold Temp Sensor (G72) is defective located?
It's usually included in the MAP sensor, if so you need a new MAP sensor or it has a duff connection/wiring fault, it could be waterlogged depending where the plug is located.
fitted new 1 today and the wires look fine car boosts as it should ran 210bhp last week just engine management light on???
Same code?
You have FMIC fitted, if so where is the MAP sensor mounted?
yes same code and yes cupra one located underneath drivers wheel arch
