4x4 rear springs
Is the removal of 4x4 rear springs significantly different from 2wd (the manual I bought to do another job inconveniently says it doesn't cover the 4x4 - but it was the only one they had) ?
Is it basically, jack it up, remove wheel, compress spring and remove ?...
Ta in advance ...
  • 6 months later...
Did you replace the springs in the end?  I'm probably about to do the same.
