Bolero radio problem
Had an issue with the radio. Would take ages to come on, then no sound, and touchscreen unresponsive.
Parking sensors were fine though.
Following advice from earlier threads, I pulled out the fuse from the engine compartment fusebox, and all was fine again.
Is this a common thing?
Is it likely to reoccur?
Is it something I should have the dealership look at while the car is still under warranty.
1/ Not that I know of.
2/ Don't know.
3/ Seems like a good idea, just to be sure.
Mine is also very slow but only through the sd card when trying to move from folder to folder. I may try remove the fuse as you have see if it works.
