Occasional Power Steering Issue / Light flickering - vRS
Hi All,
The trusty vRS which is now on 130,000 miles has developed the above symptoms.
- When starting from cold ... no power steering for approx. 30 seconds - then it is fine for the rest of the day until the next morning.
- When driving occasionally the dashboard needles flicker... very random.
Now I've read the forum guides, searched for information and got a few suggestions but no real answer... it could be:
- Battery
- Power steering pump
- Steering angle sensor
What would you suggest I start with first?
I have full VCDS for diagnosis work and know my way round a car.
Any suggestions appreciated :)
Aux drivebelt tension, then VCDS check for the angle sensor.
Check the load sensor wire (I think) underneith the alternator hasnt frayed/snapped.
Also check your earth cable from the battery to the inner wheel arch.
Funny that the belt is noisy on start up... I will replace that first and checked VCDS for angle sensor.
Cheers :)
Isn't the aux drivebelt tension on these cars automatic with the belt tensioner roller?
Fluid level?
Load sensor wire snapped?
Hi,
I had exactly the same problem. Garage stated a possible fault in the wiring loom (Expensive). an old mechanic mate said check the battery. I did and it was the battery that was on its way out. I replaced the battery with a heavier duty one and the problem has not returned.
I hope this helps
All the best
Graham
Let me know when you have sorted the problem as mine does the exact same , also my interior light flickers randomly when I'm driving , I have replaced the battery but still getting the same symptoms
Hi,
I'd check that the bulb is not loose in the holder, good luck.
All the best
Graham
