Cranks / Wont fire.
Sent my ECU away to Darkside Developments so they could put a hardcut limiter on it, As I didn't fancy the 3 hour drive up there and back again.
Got it back today, put everything back in where it should be, making sure both ECU plugs where dry and fixed correctly.
Go to start. Turns over but wont fire.
Checked everything again and double checked that check. Still turns over and over, but wont fire. I did connect my OBD reader and it tells me that it can't connect to the ECU...
I've emailed Darkside, but in the mean time, Have I missed anything? The battery has been discontented for at least 4 days if that means anything. Do I need to reprogram the key? Has the immobilizer come on? Some kind of reset I don't know about?
:sweat:
Fixed. Sent back to Darkside who had left the ECU in like a "bench only" mode, reseted, sent back, installed, fired up.
