subtle upgrade to vRS
Hi. I am now the proud owner of an 11 plate fabia vRS.
As I will be doing a lot of milege for work, I wanted to upgrade/enhance my sound. I am loathe to change the Swing HU. Same applies for the speakers, as I still have the car under warranty and dont want any issues around that with leaking doorwells, etc.
I listen to classical music, Adele, Lenka, HeartFM, BBC4, Queen, etc. Nothing too bassy or boomy. I do like ma bass, but I like it punchy and sharp.
I also need to keep my boot space free.
So, I need some recommendations on a
 - Amp ( crossover ?) slim enough to fit somewhere unobtrusive.
 - Underseat sub ?
- Possible iphone/Bluetooth/Parrot connectivity for phoning. ( I will use the mdi/aux interfaces for music, so assume no bluetooth required for music)
Assuming I am using existing speakers. Additionally, if someone can convince me that new speakers are worth the warranty hassle and would sound good with all that road noise on the motorway, then please suggest !
Budget is ~ £500, give or take £500 ;-)
I also need some recommended installers in the Watford area or in Reading ( if it can be done in a few hours).
thanks
D
Any views on a alpine SWE-1200 ?
speaking to a installer whos worked on a VRS fabia before I was given the following suggestions:
Option 1
Focal PS165 front component speakers mounted on MDF collars
Enhance EHSW8ACT  8" active Subwoofer
Dynamat
Option 2:
Focal PS65 front component speakers mounted on MDF collars
Focal Ibus 2.1 8" active subwoofer with inbuilt 2 x 55watt amplifier for front speakers http://www.focal.com/en/plug-play/250-ibus-21-3544059750129.html
Dynamat
Option 3:
as Option 2 but with Focal ISS165 component speakers mounted on MDF collars  instead of the PS
Any views on the above ?
Since nobody is replying here, you might as well ask in the Fabia 2 section,
there are some owners that have done Upgrades.
has anyone installed an underseat sub. THe ibus dimensions are 71.5 x 344 x 250mm so wondering if it will fit nicely ?
cheers
D
