Tool Fetish
Got to be the video 2000 (not sure if thats its proper name since a picture doesn't show up on google. Its basicly a light and camera on a fibre optic cable with some motors in it so you can point it in any direction you want) for when I dropped P clip in to a Harrrier. It went from the top of the jet behind the cockpit all the way to the bottom of the fuselage :doh: After an hour of searching with this I found said P clip but it had landed in a really awkward place. Got it out in the end with mechanical fingers (another great tool) after about another hour :happy: It would have been easier to remove the pylon on the belly of the jet and take off another panel but that would have created a whole load more work. I was determined that it wasn't coming off :no: There was no way I was finding that P clip without a video 2000
It has to be the trusty hammer, the one I use is a calibrated hammer and has got me out of some problems in the past!
 I also really like using my six sided sockets, they are great when removing those troublesome tight nuts and bolts that have been chewed by previous owners!
Best tool I use the most is gotta be my set of snap on dual 80 ratchets, lovley to use !
After buy only just is a good old 32oz hammer as James said, as its often stated, if In doubt, give it Clought!!!
Mine's a 3/4" drive 36mm impact socket and 2ft breaker bar in combination with a 6ft length of scaffold pipe. Used to tighten up my Beetle's rear hub nuts to the correct torque after any rear brake work or when I replaced the rear hub seals.
Zlin, I remember that job from my type2, we had 3 off us jump on that damn scaffolding tube before it cracked off. It must have been torqued up by the "put the breaker bar against the ground and drive a bit... until it lifts the van"
