(Fabia vRS mkII) spacers 30mm or wheels 215-40-17 ? (weight / power, stability..)
spacers 30mm or  wheels 215-40-17 ? (weight / power, stability..)  (Fabia vRS mkII)
reviews!
I don't see how it's one or the other? 30mm strikes me as rather a lot...
15mm-15mm , no 30-30..
Does the whiteline RaRb is effective?
I thought installing H&R35mm-40mm and whiteline RaRb, is it necessary to put spacers or tires 215 40 r17?
Edited by EduVRS
:think:  :think: :think:  :think:  :think:  :think:  :think:
You can probably get away with 15mm spacers but not sure about the tyre widths. Another member on here was running 15mm spacers all round I think without problems, but I think the tyres were standard 205 width.
Whiteline rarb is fine in my opinion but you may want something stiffer if you're going racing...
ok thanks!  in your opinion which is more effective , 15mm spacers or tires 215/40 r 117?
One is wider tyres, but not necessarily wider tread on the road, that depends on what 215/40 R 17's you actually get,
the other is a wider track on the 205 tyres.
?Do you need 4 new tyres fitting just now,?  then maybe as well to get the 215's if you do.
Get the tyres that best suits your needs.
