Should I be worried?
Have this fault on VCDS, I have cleared it but it comes back :wonder:  Door locks and unlocks OK so not sure if there is a real fault
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Component: Tuer-SG         009 2114
   Coding: 0004854
   Shop #: WSC 73430 790 00000
   VCID: 76E3198201FB9BAEBEF-8023
2 Faults Found:
00096 - Drivers Door Central Locking (Safe) Motor (V161)
            012 - Electrical Fault in Circuit
00928 - Locking Module for Central Locking; Front Driver Side (F220)
            008 - Implausible Signal
Any help much appreciated
John
Might be worth checking the wiring in the door grommet as it opens for a broken one.
Adam
Thanks, will do. looked at the wiring diagram of the lock in the Haynes manual but it does not make it clear how the switches move in response to the lock state. may have to do a comparison with the passenger side. Just need some dry weather, as said not desperate as the lock looks like it functions OK. just worried that if it fails it is near enough impossible to get to the motor without opening the door which I may not be able to do.
John
If the door lock sign is similar to the Mark IV Golf (and I suspect they are all a progress of that design) the locks have micro-switched to confirm the lock position. These can become blocked with white grease from when the door locks are periodically lubricated at service time. Sometimes the microswitches themselves fail or there is a dry solder join to them.
