activate digital speedo
I've gotten to the bottom of most of the gadget trickery on my new Octy 2 but this one's baffling me: How do I get the digital mph in the central display area to show? i.e. get a speed where the "- - -" currently is:
best regards,
GazK
if you mean the actual speed while driving (large Digital speedo)
You need to have a Maxidot
ok, but what is the item pictured for then? It never changes from "- - -", driving or not. The manual suggests it is capable of displaying the current speed...
i think it is for the speed warning, whilst driving press the ok button on the underside of the stalk
I believe you're right Eddie.  Gives a "bong" and flashes when the set speed is reached.
aah ok... are the speeds preset or do I set them? Mind you that sounds quite annoying, of course I always stick rigidly to speed limits *cough*
you set it
so if you are doing 60mph, press the ok button then you should see 60mph in the - - - mph if you go over it will bong or do something to annoy you
aah cheers. I can see me pressing that a LOT then. Ahem.
