Drivers side door loom...
I am using aftermarket component speakers. I wired them up as before but to no avail-I was using the adaptors to the cross over then cross over to speaker and tweeter, but there is noise everywhere but there! Ill check with another cross over (only just replaced the drivers side speakers, so passenger side's still boxed!) to rule that out, if no luck I'll borrow a multimeter!
Update, it's all sorted.
Thanks for your help!
Glad you got it sorted. ....
Sent from my Samsung S3
Glad you got it sorted. My drivers door electrics started playing up, found water in the door module connector. 2 pins corroded and broken on the module, and one terminal corroded and broken on the loom.
Managed to replace the broken terminal, but had to fit a new module/motor.  :wall:
  • 5 years later...
Would any another front drivers side window motor fit my 2004 mk1 ambient city? Just trying to widen my options as 3 off the connector pins have broken on mine
4 minutes ago, lurch said:
Would any another front drivers side window motor fit my 2004 mk1 ambient octavia? Just trying to widen my options as 3 of the connector pins have broken on mine I
