ESP Retrofit
Is an ESP retrofit a possibility on an Octavia without too much faff?
I'm guessing that it's only really possible if you have a donor car to source all the bits from, but thought that I'd ask the question anyway.
I'm guessing not possible?
Probably cheaper to change car.
I don't think it would actually be to much work.
You would need to swap the ABS over to an ESP one and also fit the motion sensor (yaw sensor is it?) but I think most of the other bits are the same.
Phil
