17569 and 17564 fault codes plz help
got these fault codes guys 17569 manifold temp sensor circ
17564 manifold abs pressure sensor circ cars sounds like its running on 3 cyclinders
plus no boost and codes won't delete??
Has your MAP come unplugged or broken the wires? Both those codes refer to the MAP sensor since the manifold temperature sensor is integral.
changed the map sensor cut a harness of 1 from a scrappy and soldered it sounds like it running on 3 cyclinders although got the boost back just abs/traction and management light on
