Alloy Cleaning...
Good Morning.
In the past I have only ever cleaned my alloys with soap and water...then sealed them.
I have now got myself some `Bilberry Wheel Cleaner` and some `Iron X`
Unfortunately I am a little unsure how to best use them...
1. Should the dirty alloys be dry or rinsed off before the `Bilberry` is applied?
2. Will the `Bilberry` have any adverse effect on the brake callipers or the wheel weights?
3. Once clean, is there any point in then giving them a dose of `Iron X`?
3. If so, with the `Iron X` have any adverse effect on the brake callipers or the wheel weights?
Many thanks.
Mike.
1. My preference would be a dry wheel as it will allow the Bilberry to cling and work it's magic, leave to dwell agitate with a good wheel brush and PW rinse. Adjust dilution to suit the job.
2. Shouldn't do in my experience
3. Yes absolutely but go Bilberry first so that the Iron-X is only working on the ingrained/embedded iron, otherwise it's wasteful and the chemical reaction will be spent up on the surface brake dust which you could have removed with Bilberry.
3(part 2 ;) ) . My experience again is that it shouldn't do.
take care Iron Removers all smell like ass.
Opppps...sorry about my numerical problem there!!!
Thank you so much `Sparkly` for your valued advice.
Regards
Mike.
+1
What he said Mike :rock:
+1 again - I use autosmart "smart wheels" but it does the same thing really.  The rest of the steps are the same as what I do.  On really bad wheels, tardis can also assist with tar spots the wheel cleaner doesn't quite shift. :)
Thanks, everyone. What a fab forum this is.
Regards
Mike.
