Is it possible?
Does anyone know if its possible to have a partial failure of the clutch position sensor? Reason i ask is i still have the overreving problem when changing gear, revs rise around 250 rpm as the throttle pedal is released and the clutch pedal is depressed. However the switch still turns off the cruise control ok. The overreving only occurs during fast gear changes but i am defintley not not pressing the clutch pedal before releasing the throttle.
Thank you.
