Dash Lights
Yep! As L-Y-K said, they are SMD LEDs soldered on the circuit board. But then again...with a little bit of soldering...
But, How you did it? I tryed to do that and when I goy every leds changed, It dindt lights because green lights needs less voltage than blue ones...... so....I tried with smd leds..... What kind of leds do you used??
Thanks!
Paco.
[email protected]
You have to de-solder a few resistors and put new ones in different locations to brake the 1x4LEDs connection into 2x2LEDs connection. I spent over 4 hours with a multimeter to figure out where the traces go. I used blue SMD LEDs from Kingbright (60mcd @ 3,6V, code: KM2520MBC03) - they are smaller than the originals!
Unfortunately I didn't took photos of new resistor locations :(
god if i had the patience to do it i would! looks excellent
