New Gearbox / Errors
Hi Guys, Just scanned the father in laws car with vag com (original, he has just had a new dsg gearbox replaced I got the following errors, can anyone point me in the right direction to resolve. Errors come straight back after clearing all dtc's.
Saturday,15,March,2014,13:01:28:13498
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: TMBDS21Z882173611   License Plate: JDFLOYDAFTER
Mileage: 187030km-116215mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 02 03 09 15 16 17 19 25 42 44 46 52 56
VIN: TMBDS21Z882173611   Mileage: 187030km/116215miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 021 LB    HW: 03G 906 021 AN
   Component: R4 1,9L EDC  000AG  9251
   Revision: --H08---    Serial number: SKZ7Z0H4948037
   Coding: 0000038
   Shop #: WSC 73430 790 00000
   VCID: 6AD03442454B534E253-803F
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans        Labels: 02E-927-770.lbl
   Part No SW: 02E 300 044 F    HW: 02E 927 770 AE
   Component: GSG DSG         081 1404
   Revision: 09908010    Serial number: 00000707180718
   Coding: 0000020
   Shop #: WSC 04940 001 00001
   VCID: 18343E8A2BA711DE437-804D
3 Faults Found:
18290 - Powertrain Data Bus
            P1882 - 000 - Missing Message from Electric Parking Brake Controller
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 255
                    Reset counter: 40
                    Mileage: 187035 km
                    Time Indication: 0
18261 - Powertrain Data Bus
            P1853 - 000 - Implausible Message from ABS Controller
             Freeze Frame:
                    Fault Priority: 0
                    Reset counter: 40
                    Mileage: 187035 km
                    Time Indication: 0
18275 - Powertrain Data Bus
            P1867 - 000 - Missing Message from Steering Wheel (J527)
             Freeze Frame:
                    Fault Priority: 0
                    Reset counter: 40
                    Mileage: 187035 km
                    Time Indication: 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   VCID: 3F86B5166E4906E6A2D-806A
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 00000005716460
   Coding: 00880F030004140043110D000000000000097B075C000000000000000000
   VCID: 6FE625567EA9B66672D-803A
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 240408 022  0601
   Coding: 00055223
   Shop #: WSC 73430
1 Fault Found:
00834 - Signal for Activation of Heated Rear Window
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 167
                    Mileage: 187035 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 14.30 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1Z3EP+
   Coding: 0020788
   VCID: 3D7ACF1E644514F6B01-8068
   Subsystem 1 - Serial number: 6332MSME3C10617BC
   Subsystem 2 - Serial number: 6342MSME3A15674FN
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BF    HW: 1K0 953 549 BF
   Component: J0527           051 0101
   Coding: 0010012
   VCID: 77F61D3606F9FEA6AAD-8022
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 822 D    HW: 1Z0 920 822 D
   Component: KOMBIINSTRUMENT VD1 1610
   Revision: V1610056    Serial number: SKZ7Z0H4948037
   Coding: 0003101
   Shop #: WSC 00791 209 91614
   VCID: 3668D0324173C7AE71B-8063
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 P    HW: uŠg
   Component: J533__Gateway
   Revision:       Serial number: 0000K084150DD7
   Coding: ED801F020002021303
   Shop #: WSC 00000 000 00000
   VCID: 346CEA3A570FD5BE4FF-8061
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 1610
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         006 1204
   Coding: 0000564
   VCID: 3874DE0A4B6731DE637-806D
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.069 H08 1901
   Shop #: WSC 73430 000 90108
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 CN
   Component:    KSG              0401
   Coding: 80D002003F098505095B010004CC
   VCID: 7EF8081229C3CFEEE9B-802B
   Subsystem 1 - Component:   Sounder n.mounted
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000564
   VCID: 3972DB0E706D28D69C9-806C
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
   Component: Radio FO3       020 0041
   Revision: 00020000    Serial number: SKZ7Z3H0065322
   Coding: 0000200
   VCID: 2E58F852B923FF6E39B-807B
End   ---------------------------------------------------------------------
Edited by techi
  • 1 year later...
For the electric brake:
http://safebraking.com/electronicelectric-parking-brakes-one-more-reason-to-do-a-brake-job-right/
Powertrain Data Bus: Missing Message from Steering Wheel Electronics Possible Symptoms
  • Malfunction Indicator Light (MIL) ON
  • Cruise Control not working
Possible Causes
  • Wiring and/or Connector(s) from/to Steering Wheel Electronics (J527) faulty
  • Cruise Control System Switch (E45) faulty
Possible Solutions
  • Check Wiring and/or Connector(s) from/to Steering Wheel Electronics (J527)
  • Check/Replace Cruise Control System Switch (E45)
Special Notes
  • When retrofitting Cruise Control make sure to have the Wiring done right. If you activate the Cruise Control prior to properly retrofitting the Wiring and the Cruise Control Lever/Stalk you will also find this Fault Code being stored.
Signal for Activation of Heated Rear Window 009 - Open or Short to Ground
             - Does the rear window heater work?
