Ahhhhh battery code on vrs
Good evening,
I'm lost - I've seen a great deal on euro car parts on a Bosch battery - code is 075.
Basically on other sites I'm getting different numbers, my car is 56 plate, 2 litre petrol .....
Is the 075 the right code ?
Bosch S4 Battery 075 4 Year GuaranteePart No.: 444770757 List Price £87.54
Our Price £62.47
I put a Bosch S5 096 battery in mine. Fits in fine. Loads of cranking power - 780a cca.
Justcarbatteries website. Was £80 delivered.
That's different dimensions to the S4 - isn't there a definitive list / dimensions for the vrs petrol..?
Isn't there a eurocarpart person on here? Lol
In various site seen the following been variants quoted - they can't all fit?
027
075
096
Well according to the battery ive got on the dimentions are ( according to part number  1j0915105ac)
242 L
175 W
190 H
makes it an 027.....
Could i use a 075 ? 20mm differance plus they are cheaper £60 v £75
242 L
175 W
175 H
242 L
175 W
190 H
242 L
175 W
175 H
but are they as good.
You really want more ah than the oem battery and higher cca. Unless you are looking a big money batteries you want the most ah and cca your budget can afford.
ordered an 075 - measured my battery and it was the same size.
What spec did you get? You really want have used it as a chance to get a higher ah battery as people have issues with it being quite low for a derv.
My mums 1.3 cdti corsa has a bigger ah and cca battery than my vrs derv had
I got a 096 fits all octys.
The Bosch S5 (5 year warranty) 096 really is a tremendous battery.
027 was OEM install on tfsi, 096 on tdi. Battery tray fits both, 096 is normally only marginally more expensive but more powerfull. Make your own decision regarding the weight difference. 096 would be my choice. Dale
