Wheel spacers?
If i were to fit 15mm rear spacers and 10mm front ones to a standard suspension setup
Would this look odd?
Would I need tracking done?
I plan on coilies in the future.
will look good, does'nt effect tracking. make sure you get hubcentric spacers. I just fitted 20mm on rear.
As said above, make sure you get hubcentric, bit more money but worth it.
How wide you go depends on how brave you are :)
16mm hubcentric on the rear of mine.
Wouldnt go any wider.
20mm on rear of mine - keep it legal
  • Sponsor
10mm front and 15mm rear tends to be the perfect combo for the Octavia 1Z in my opinion, wheels depending though.
Damian @ DPM Performance
Okay great :)
Any pics pls? I have the 18' standard alloys and like I said I plan to lower it on coilies in the near future.
Will the fact the wheels are pushed out wider affect how low I can go?
Also I'd deffo go for the hub centric ones however if I went for that extra poke ' 20mm ' would 10 on the front still be ample?
Right. I'm just about to purchase a set.
20 for the rear and 15 for the front. Hub centric and with radius bolts and I'm running stock alloys.
Is this legal at this width?
As long as no tread pertrudes the arch your fine.
Front will bring your et down to 36 rear down to 31. That's going on 18" zeniths. You'll have plenty of room to play with ;)
Ah okay! With an ET of that I'm pretty much in the middle when it comes to the scale.
Edited by T555VRS
I'm on 8.5x18 et25 all round.
