Demon shine snowfoam (green stuff)
Hi Folks
Can someone help I've been given some of the above to try but can't find if it is wax safe . There are some say yes and some no and carplan say if you've used a good quality wax it will be ok .
Has anyone used it or answer my question .
Cheers whoosh
Best way to explain it is to expand on what Carplan have said.
If your car wears a 3 wk durability Show Wax, then Demon Foam at strong concentration, left to dwell 15 minutes may well degrade it significantly.
If your car wears Collinite 845 and you use Demon Foam at mild concentration left to dwell 5-10 minutes I doubt it will make a noticeable difference.
There is with all these things a degree of user input to the outcome.
Also the above will be true for many "Wax Safe" snowfoams.
Use it, learn what it does, then perfect your technique.  the beauty of spoiling your wax layer is that you only need to top it back up with another layer, no real harm done.
Come back and give us a review on this.
Yup, what he said.
Thanks folks car hS a couple of coats of colly 846 and wax sealed with carlack .
Will give it a go
Cheers whoosh
