VCDS Adaptation Map - Octavia MK3
I understand on the Octavia MK3 if cornering fogs are enabled (as long as low beam is on) they will illuminate on left/right but also both will illuminate on reverse.
If this applies to your MK3 and have access to VCDS would you possibly post an adaptation map for Central Electrics (09)
Would also be handy if your car had dipping kerb mirror (passenger side) as mine isn't functioning quite right.
An example of what I'm after:
https://drive.google.com/file/d/0BxOfluLej5eTZWJMQS0xeEpyMFU/edit?usp=sharing
If you're unsure how to obtain a map check here:
http://www.audienthusiasts.com/Article_VCDSAdaptationMap.html
I'm aware mine is a Leon MK3 but most coding is the same.
Many thanks
