Amundsen+ in the blackline
Hi all quick question does the Amundsen + that came as standard in the Blackline have Europe maps and are they enabled
or do I need to do anything with vcds to activate them switch location etc. Going to France at the weekend could do with them.
While im at it can the headlights be switched to continental mode or do they have to be xenons? I have full VCDS have a feeling it only works with xenons but
if you can adjust the main beam for driving on the right this would be good.
I think European maps are there without any fiddling required, do a test on your drive.
I think you have to take the lights out and switch an internal reflector, there was a guide on here for the PRE-FL and I am not sure if FL lights are the same?
