Wiring through bulkhead
Is it possible to put more wires through the bulkhead behind the glove box. I have looked a mine and the holes appear to filled with foam tape. I want to put these in for charging and  fridge in my caravan.
Have a look at this
Towing wiring
Started by Yety, 31 Jan 2012 21:06
Talking to my local dealer I found that there is a another loom through the bulkhead below the glovebox. This has a rubber plug alongside the cable loom. If the battery is removed you can see this plug. I now have a fused cable run from the fusebox by the battery right through to the split charger behind the nearside rear panel in the boot
