VCDS in Hampshire/Surrey area
Morning all, I hope someone may be able to help?
I am after somebody in the Basingstoke area (M3 corridor) with access to VCDS. I have checked the 'map' but there is nobody shown local that is also still active on this site (most over 18 months). I have sent a couple of PM's but so far with no luck.
I had DPF, EML light come on last week. Have cleared DPF through normal means but a bit of research shoes I still have a USA made sensor which was a common issue. I have purchased a Malaysia version which is the current Skoda part. Although this is just a 5 min fitting I am aware there is process on VCDS that needs to be carried out for car to recognise new sensor?
If anyone can point me in the right direction, or to a local garage that doesn't charge the earth to do the same I would be very grateful.
Thanks in advance,
Monty
