head gasket
as above she gave up today after loosing water for the past 2 months best place to buy head gasket and head bolts plz guys any links be great
Definitely go for oem PD150 headbolts - From TPS.
I can't remember where my HG came from, but it was an uprated one, but really as long as you use PD150 bolts (20% more strength than PD130) then you may as well use stock replacement gasket also from TPS.  Check which hole (1,2 or 3) one you have on the tab sticking out the front, although technically the head / valve clearance should be re-measured once sorted, and suitable gasket bought accordingly - That's a garage / head machining job, not something you can decide on this forum.
what about the head stud kit from darkside worth the money?
