Correct CanBus
Evening!
I have a 2005/55 Octy with the basic Stream stereo and would like to upgrade to the Bolero or Columbus unit. I'm aware I will need to change the CanBus Gateway to avoid the dredded battery drain so is this the correct one?
http://m.ebay.co.uk/itm/191085346455?nav=SEARCH
Billy.
Edited by billywhiz040480
That does seem very cheap.
Two things:
Firstly that is a Chinese clone of the Skoda part. There was a discussion on here a couple of years back from a respected member thinking of buying something from a similar source.
The consensus seemed to be that they were probably made in the same factory...
Secondly, to retrofit a Columbus you don't <i>have</i> to change to CAN gateway. There is the possibility to update the firmware (to 3810) and apply a 'patch' that modified the firmware to overcome battery drain in pre-2007 Octavias.
Quite well documented on here, My Gti, VW Navi and GPS Underground sites/forums.
Continental VDO gateways are made in the Czech Republic and not in China
The stickers are slightly different too
I picked up an AF for £50.
Item location: confirmed as Coventry (postmark) and next day delivery.
Made in CZ :) :)
